January 2, 2023 at 6:21 pm
Tank you for your reply. Here are more information about my case :
- at the interface, i only specified "coupled wall" option.
- i run my case as steady flow so there is no way to run a 'longer time'
- i try to rise residuals and tested many models and many methods to calculate energy equation but nothing worked
- concerning the mesh, i activated face meshing and used element size on every edge. I tested global size of 50µm, 25µm and 10µm but the results only changed about few K.
As suggested in the user guide you linked, i tried different value for under-relaxation factor of energy equation but it didnt solve my problem.
Thanks for your help,
Sincerely, best wishes for the new year,
Mickael
