January 3, 2023 at 8:06 am
Hi SRP, thank you for the tips.
As I check the previous forum discussion on the synergy angle, the reply by Rob is "If you're using Fluent you can use a Custom Field Function, you may also need a UDF to move some of the gradient data into User Defined Memory. More details on the latter in the documentation.".
Which lead to my next confusion, where may I find the documentation for more details?
Thank you.
