Hi Najeeb,
If you plot the vector principal stress, you will get the orientation vector plot of the maximum, middle, and minimum principal in the global coordinate system. Then you can export those results into a text file by doing a right-click export, and you will get orientation values for the maximum, middle, and minimum principal in the global coordinate system.
