Hi, having the large result data set and loading it back into the interface do take the time to parse them into the result quantities, that delay is normal based on the hardware you had, to reduce the lag, you can delete the all the result and load the reuslt and then recreate it again, use an GPU quilified for ANSYS to boost the perfrmance in loading the results
https://www.ansys.com/content/dam/it-solutions/platform-support/gpu-accelerator-capabilities-2022-r1.pdf
cheers, Ram
