Logic is to start sampling when you see your flow starts settling, montinor plots flucatuating over certain mid value, etc. I usually try to sample over N flow thru times / flow residence time (think in that if you want to gather statistics of a partially resolved turbulence). Sampling interval: keep using the default if you want to consider every event/time step in the calculation of mean values.
