Hi Dave,
thanks for your support. I added an extra node and some code to delete the surf152 elements of the last step.
I also changed the node selection a little bit to:
cmsel,s,external,nodes ! Select nodes for esurf
esel,all ! Select elements for esurf (including the “external” nodes)
esurf ! Creation of surface elements
it differs from the former version:
cmsel,s,external
esurf,nakt
I’m not sure if my current version of nodal and element selection previous to esurf is doing the right thing.
The whole script would look like this:
/prep7 ! Pre processor
/GOPR
*get,nmax,etyp,,num,max ! nmax=name of resulting parameter, Entity=etyp aka Element typ,ENTNUM=blank, Item1=num,IT1NUM=max aka maximum number, Item2=blank,IT2NUM=blank
eakt=nmax+1 ! maximum element typ number +1
*get,mmax,node,,num,max ! mmax=name of resulting parameter, Entity=node,ENTNUM=blank, Item1=num,IT1NUM=max aka maximum number, Item2=blank,IT2NUM=blank
nakt=mmax+1 ! maximum node number +1
n,nakt,0,0,0 ! Creation of extra node
et,eakt,surf152 ! Surf152 Elements
keyopt,eakt,5,1 ! Extra nodes
keyopt,eakt,9,1 ! Radiation with form factor real constant
keyopt,eakt,11,1 ! Nodes DOF-TTOP
r,eakt,1,5.8e-8 ! Stefan Boltzman constant
mp,emis,eakt,epsilon ! Emissivity coefficient
mat,eakt ! Material assignment
type,eakt ! Type assignment
real,eakt ! Real constant
esel,s,ename,,surf152 ! Element selection of surf152 elements
cm,ELsurf152,elements ! Create a component which includes surf152 elements
edele,ELsurf152 ! Deletion of former surf152 elements
d,nakt,temp,tamb ! Temperature of the the extra/space node, Temperature=ambient Temperature
alls
toffst,273 ! Specifies the temperature offset from absolute zero to zero, 273 for the Celsius system
/solu ! Re-entering the solution
Greetings
John M.
