Hi Sneh,
Your model looks properly constrained and it does not have any contact, so that should not be the issue. You have warning related to meshing, it might be because of single elment across the thickness. Can you try remeshing the part with finer mesh and see if your issue gets solved?
Thanks,
Akshay maniyar
