1, Is your model well constrained (boundary conditions), ie. no rigid body motion? How do you load your model, by force or displacement?
2, Consider "adjust to touch" to ignore the initial gap is that's acceptable.
3, Also check and see if your substep size is small enough to calculate the correct contact status.
