Hello Mustapha,
You can check the validity of *LOAD_BLAST_ENHANCED using the following formula:
See the LS-DYNA user manual vol I for more details.
To use *LOAD_BLAST_ENHANCED in WB LS-DYNA, you can create a command snippet:
To specify the faces of the structure where the blast load will be applied, you can create a named selection with an ID:
Let me know if this helps or not.
Reno.
