As you know, the override mesh can specify mesh size. So you know the layer thickenss and you know the approximate mesh size, you can use the thicknes divided by an integer to be close to the desired mesh size. "set maximum mesh step" is the mesh size to be used.
If you are a commercial user or want to buy commercial license, you can contact sales. https://www.ansys.com/contact-us
