Hallo, i just try to do the same in Lumerical and get similar results as @jordankim. I try to generate the same structure with LSF file, just to verify if my code (structure) is correct. Witht the MatLab LSF file format, everything is working and i can generate the structure. Did you resolved the issiu in some way, and if you did, can you post some python example ?
