Hi Paras,
You can use the same model available in the Explicit Dynamics system for Harmonic Acoustic analysis. But what is the data that you are looking to be used from the Explicit analysis? Are you looking for some result item that should be used in Acoustic analysis?
Please elaborate more on the application you are interested in simulating.
Ashish Khemka
