January 9, 2023 at 6:20 pm
I introduced gap of 1 full period ~ 6 mesh shells between 2 override regions. I still find that uniform mesh step got applied across both DBR periods. The value of actual step was different from both the steps I put in 2 mesh override region. My python script is as below
import importlib.util
spec_win = importlib.util.spec_from_file_location('lumapi', 'C:\\Program Files\\Lumerical\\v222\\api\\python\\lumapi.py')
import numpy as np
lumapi = importlib.util.module_from_spec(spec_win)
spec_win.loader.exec_module(lumapi)
if not ( 'fdtd' in locals() or 'fdtd' in globals() ):
fdtd = lumapi.FDTD("A")
N_DBR1=4
N_DBR2=3
n1= 3.487
n2= 2.941
n3= 2.990
NUM_MESH_PER_DBR_PERIOD=6
fdtd.switchtolayout();
fdtd.deleteall();
################## declare simulation, structure and mesh groups
props={"dimension":"2D","x": 0, "x span" :2e-6, "y min": 0, "y max": 4e-6,
"z": 0, "mesh accuracy":1,"set simulation bandwidth":1,
"simulation wavelength min":1e-6,"simulation wavelength max":1.1e-6}
fdtd.addfdtd (properties=props);
props={"x": 0,"y": 0, "z": 0,"name":"epilayer_struct"}
fdtd.addstructuregroup(properties=props);
props={"x": 0,"y": 0, "z": 0,"name":"mesh_group",}
fdtd.addgroup (properties=props);
################# draw substrate
y_pos=0e-6;
t=2e-6;
props = {"x":0,"z":0,"x span":1e-6,"z":0,"z span":0,
"y min": y_pos,"y max": y_pos+t,"index" : n1 , "name":"substrate" } ;
fdtd.addrect(properties=props); fdtd.addtogroup("epilayer_struct");
y_pos+=t
####### DBR 1
print("DBR1 bot : " + str(y_pos) )
y_pos_DBR1_bot=y_pos
for k in np.arange(N_DBR1):
t=89.3e-9;
props = {"x":0,"z":0, "x span":1e-6,"y min": y_pos, "y max": y_pos+t,
"index" : n2,"name":"DBR1_n2", "alpha":0.2} ;
y_pos+=t
t=75.3e-9;
"index" : n1,"name":"DBR1_n1"} ;
fdtd.addrect(properties=props);fdtd.addtogroup("epilayer_struct");
y_pos+=t
y_pos_DBR1_top=y_pos
print("DBR1 top : " + str(y_pos) )
####### add mesh DBR1
dy=(y_pos_DBR1_top-y_pos_DBR1_bot)/N_DBR1/NUM_MESH_PER_DBR_PERIOD
print("dy mesh DBR1 : " + str(dy))
props = {"x":0,"z":0,"x span":1.5e-6 ,"y min": y_pos_DBR1_bot, "y max": y_pos_DBR1_top,
"name":"mesh_DBR1","set maximum mesh step":1,
"override y mesh":1,"override x mesh":0,"override z mesh":0,"dy":dy} ;
fdtd.addmesh(properties=props); fdtd.addtogroup("mesh_group");
####### DBR 2
print("DBR2 bot : " + str(y_pos) )
y_pos_DBR2_bot=y_pos
for k in np.arange(N_DBR2):
t1=87.8e-9;
t=t1;
props = {"x":0,"z":0, "x span":1e-6,"y min": y_pos,"y max": y_pos+t,
"index" : n3, "name":"DBR2_n3","alpha":0.5} ;
y_pos+=t
t2=75.3e-9;
t=t2;
"index" : n1,"name":"DBR2_n1"} ;
y_pos+=t
y_pos_DBR2_top=y_pos
print("DBR2 top : " + str(y_pos) )
####### add mesh DBR2
dy=(y_pos_DBR2_top-y_pos_DBR2_bot)/N_DBR2/NUM_MESH_PER_DBR_PERIOD
print("dy mesh DBR2 : " + str(dy))
#introduce gap in 2 mesh override regions
props = {"x":0,"z":0,"x span":1.5e-6 ,"y min": y_pos_DBR2_bot + (t1+t2) ,"y max": y_pos_DBR2_top ,
"name":"mesh_DBR2","set maximum mesh step":1,
"override y mesh":1,"override x mesh":0, "override z mesh":0,"dy":dy } ;
fdtd.addmesh(properties=props); fdtd.addtogroup("mesh_struct");
#### LINE MONITOR to get y mesh
props = {"monitor type":"Linear Y","x":0,"z":0,"y min":1.5e-6 ,"y max": 4e-6} ;
fdtd.addpower(properties=props);
fdtd.run();
######### y mesh
y=fdtd.getresult("monitor","y") ;print( np.diff(y[:,0]) )
