I'm not able to load the udf.library when using an input parameter. I report the compile console script at the end.
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nLe fichier sp�cifi� est introuvable.
\n\nC:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\libudf.dll
Error Object: #f
I have registered the frequency as the input parameter in fluent. My UDF like :
Copied C:\Users\...\TRIAL UDF\UDF\platetest_input.c to libudf\src
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_host\SConstruct" ")
1 fichier(s) copi?(s).
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\scons_default.bat "libudf\win64\3ddp_host\scons_test.bat" ")
Creating user_nt.udf file for 3ddp_host ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ")
(chdir "libudf")(chdir "win64\3ddp_host")
C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host>rem
C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
'cl.exe' n'est pas reconnu en tant que commande interne
ou externe, un programme ex?cutable ou un fichier de commandes.
'clang-cl' n'est pas reconnu en tant que commande interne
scons: Reading SConscript files ...
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\SConstruct", line 8, in
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\SConstruct", line 18, in
Compiler used is "C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\clang-cl
Linker used is "C:\PROGRA~1\ANSYSI~1\v212\fluent"\ntbin\clang\bin\lld-link
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\SConstruct", line 148, in
Copy("C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\win64\resolve.exe")
Copy("C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\platetest_input.c", "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\src\platetest_input.c")
UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d in position 324: character maps to
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\SConstruct", line 172:
generate_udf_source(t,s,env)
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_host\SConstruct", line 87:
for line in f:
File "C:\PROGRA~1\ANSYSI~1\v212\fluent/../commonfiles/CPython/3_7/winx64/Release/python\lib\encodings\cp1252.py", line 23:
return codecs.charmap_decode(input,self.errors,decoding_table)[0]
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_node\SConstruct" ")
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\scons_default.bat "libudf\win64\3ddp_node\scons_test.bat" ")
Creating user_nt.udf file for 3ddp_node ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ")
(chdir "libudf")(chdir "win64\3ddp_node")
C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node>rem
C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 8, in
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 18, in
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 148, in
Copy("C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v212\fluent\ntbin\win64\resolve.exe")
Copy("C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\platetest_input.c", "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\src\platetest_input.c")
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 172:
File "C:\Users\...\TRIAL UDF\Trial UDF input_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 87:
for line in f:
Done.
