Hi Sneh,
The model is very thin and the load value is quite high, may be because of that you are getting the above error. As it is very thin, have tried using shell elements insted of solid elements? Shell elements are recommended for thin parts as they will portray the bending behavior quite accurately with much fewer elements than their solid-mesh counterparts.
Thank you,
Akshay Maniyar
