Yes, you need to have the Top-Down View enabled form the View ribbon. If you rotate the PCB even half a degree those tools are greyed out and you can't use them.
New Post - Reply To: What disables Draw Geometry and Circuit Elements in SIwave 2021R2 and how to re-enable them?
