Set up will show the initial condition, which is from the CAD. In results it'll be wherever the spinning part finished up. In geometry find the centre of the turbine unit (you may need to slice/chop the model to create a vertex). I'm not sure how rotation is set in CFX, but it'll be defined in the fluid zone somewhere - that need to be the same as CAD value.
