January 10, 2023 at 1:42 pm
Hi, If you have access to a Granta products (EduPack for teaching or Selector for Research), you'll have access to similar databases to the Campus Platics one.
Below a screenshot of results you can get in terms of material properties for the Nylon66 in Granta Selector.
You have different records given the state of the polymer (dry vs conditioned...) and from different sources. Export function exists and data are already digitalized so no need to redo it and you can export easily to most common commercial FE softwares.
Cheers
David
