Time domain incident wave surface animation will be included in Release 2023 R1, which should be available soon. This will allow you to display the long- or short-crested wave motions at the same time as the buoy movement in an Animation result.
In the current versions (Release 2022 R2 or older), you would need to use the Aqwa Graphical Supervisor (AqwaGS), which can only display a long-crested wave.
I hope this helps.
Mike
