Hello Igor Savin,
It seems that this command is required to open GUI to export the results, but the cluster does not support graphic card to open Maxwell.
Please review the PyAnsys and PyAEDT, https://github.com/pyansys/pyaedt and https://aedt.docs.pyansys.com/release/0.6/. PyAEDT could run with non-graphic mode.
Another option is to download the files of the model and results from the cluster to your local machine, and use the local machine to export the results. Thanks.
HDLI
