The same issue when using built-in compiler in 22R2.
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_node\SConstruct" ")
1 fichier(s) copi?(s).
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\scons_test.bat "libudf\win64\3ddp_node\scons_test.bat" ")
(chdir "libudf")(chdir "win64\3ddp_node")
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
File "C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 8, in
File "C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 18, in
Compiler used is "C:\PROGRA~1\ANSYSI~1\v222\fluent"\ntbin\clang\bin\clang-cl
Linker used is "C:\PROGRA~1\ANSYSI~1\v222\fluent"\ntbin\clang\bin\lld-link
File "C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 152, in
Copy("C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v222\fluent\ntbin\win64\resolve.exe")
Copy("C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\platetestinput.c", "C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\src\platetestinput.c")
UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d in position 324: character maps to
File "C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 176:
generate_udf_source(t,s,env)
File "C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf\win64\3ddp_node\SConstruct", line 87:
for line in f:
File "C:\PROGRA~1\ANSYSI~1\v222\fluent/../commonfiles/CPython/3_7/winx64/Release/python\lib\encodings\cp1252.py", line 23:
return codecs.charmap_decode(input,self.errors,decoding_table)[0]
Done.
When I click on LOAD
m...: Opening library "C:\...\FLUENT\TRIALUDFINPUT\TrialUDFinput_files\dp0\FLU-1\Fluent\libudf"...
ERROR: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
Le fichier sp�cifi� est introuvable.
C:\\...\\FLUENT\\TRIALUDFINPUT\\TrialUDFinput_files\\dp0\\FLU-1\\Fluent\\libudf\\win64\\3ddp_host\\libudf.dll
Done.
