January 11, 2023 at 3:56 pm
I am using ANSYS R2021 R2. Can I also ask how I can find out how much heat each of the solid cubes are releasing? (I have a fluid domain which contains a bunch of solid cubes that generate 7W of heat. Initial temperature of solids > initial temperature of fluid)
I can only find the total heat transfer rate under 'fluxes', but don't know how to get the heat released by each solid cube
thank you in advance
