You can see that beams in the structure failed along a max shear plane and the structure lost all stiffness.
You could simulate that if you create a geometry that has a small flaw in the geometry that will seed this mode of failure.
If you have perfect geometry, that mode will not be initiated and you will just get uniform compression.
