From the paper, the mesh should look like this...
To get that mesh, you need to have space between the carbon fibers in red. Also, you have to subtract the carbon fibers from the resin block in purple so that the resin block has holes where the carbon fiber fills the holes.
Your resin block has no holes in it.
Your carbon fibers have no space between them.
You need to fix those issues.
