Please do not confuse between DPM Reports and DPM Sample File and Injection File. The latter two are quite similar and DPM sample file can be "usually" used as injection file.
Tha mass flow appearing in the header is the mass flow rate associated with that line as each line is referring to a stream / parcel.
Please refer to Point Properties for File Injections in the Fluent User's Guide to check different injection file options.
