Whatever you return back in Ansys Fluent should be per cell volume. Example for continuity the Source term dimension should be in kg/s/m³. As in the UDF everything is "dimensionsless" you should take care about the right dimensions and magnitude.
New Post - Reply To: Scalar source term
