January 12, 2023 at 2:46 pm
Flux per cube during a steady state simulation. So do I just click new report file --> surface report definition --> report type: integral --> field variable: wall fluxes and total surface heat flux and then select the solid cubes under 'surfaces'?
If I have already created a named selection which contains all of the 55 solid cubes together, do I have to create a separate cell register for each cube so I can see how much heat they are releasing individually, which I then select under 'surfaces'?
thank you very much again!
