Hi Peter,
Understood. But it would take out the pressure/temperature parameter when I’m performing the respective ones. Or when I get the critical parameter for both for example at 22.345°C, 2.235MPa, the pipe will buckle? On the other hand, when I suppress the temperature load, the pressure load multiplier that I got were all in negative. Did something went wrong?
