The system is indeed out of memory as shown in the error message. As the patch antennas are not complex, they should not take much memory unless the mesh settings are extremely fine.
Are you simulating this antenna with fine mesh settings?
Please try to reduce the number of passes and keep the slider at a coarse resolution under curved surface mesh setting.
Thanks,
Chinmay
