You can create an Input paramter derived from another parameter in the WB. Best to frist create an input parameter in Ansys Fluent. Then in the WB you say it is for example equal to Input Paramter 1. Now in Fluent with that input you can do whatever you want (you can use it to create inside expression etc..). Please test first in a dummy example if this works for you and your UDF.
