January 13, 2023 at 6:08 pm
If you do not see the parameters in Spaceclaim - > groups tab, but shows up in WB parameter set, you can use script to delete the parameter
- In Workbench project page, Go to File -> Scripting -> Open Command Window
- Copy and paste the following commands and hit enter to delete the parameter
p2 = Parameters.GetParameter("P2")
parameterizedEntity = p2.GetAssociatedEntityProperties().keys()[0]
parameterizedProperty = p2.GetAssociatedEntityProperties()[parameterizedEntity][0]
p2.Disassociate(parameterizedEntity, parameterizedProperty)
p2.Delete()
In the commands above, we are deleting parameter named P2.
You can change the name to delete a different parameter
