Mesh module is not compatible with Mechanical systems. You need to create mesh in "Mechanical Model" system instead.
If you have already created mesh in "Mesh" module, you can click on the downward black triangle in upper left of the "Mesh" system and use "Replace with Mechanical Model"
-Aniket
