In the first image, the maximum deformation is 2.69e-6 mm whereas in the second image the maximum deformation is 57 mm. You are using "True Scale" in both the cases (see "Result" tab > "Display" options > "1.0 (True Scale)"). It is much easier to see 57 mm than 2.69e-6 mm.
If you want to visualize the deformation in the first case, change "1.0 (True Scale)" to "Auto" or "0.5x Auto".
Hope this helps.
