You might try using different Flux-type in Pressure-Velocity Coupling in Solution Methods. Also, try changing the URFs. Might happen due to bad quality mesh also.
There exists the difference between the scaled and unscaled residuals. You can find more about them here: 33.15. Monitoring Solution Convergence (ansys.com)
