The MHD module will not calculate the magnetic field induced by the arc current. It is not a complete EM solver. If the arc is DC you will need to consider using Ansys Maxwell. If it's high frequency AC you'll need Ansys HFSS, low frequency will work with Maxwell. This is not a straightforward project and should be approached with caution.
