January 16, 2023 at 4:22 pm
An actually i would like to simulation HSA part drop to hit a base for review damage occur on it. and after i apply only std. G ,i didn't seem part animation that part still stay on air also.
and i try to change method as same your recommend by use drop high the animation occur part drop but actual part didn't drop to base also. I change distance between base and part to smaller but animation also same.
Below picture - use drop high method by condition drop 50 mm/s
distance between base vs part around 5 mm
Base set fixed point
(The animation show drop down but part still not hit with my base)
Do you know what issued on this ?
