The drop impact velocity is 990 mm/s. Thus it will move 0.99 mm at 1 ms. Your picture below shows the accurate motion: 0.929 mm/9.34E-4 is about 990 mm/s.
If you run the simulation further, you should be able to see the high stress generated in the impact area.
