From your results, it is obvious that the simulation time is too short: please use 100 times more than the current time. you may also need to use finer mesh at the coupling regions and the nano particle with override meshes.
Please refer this post for more information:
Ansys Insight: Why my simulation result is different from published paper or experiment?
