Hello Victoria,
Please let me know what was the error message with the standard initialization. If you patch each solved variable individually, do you have the same error? If so, at which point?
For the hybrid initialization, SIGSEGV is a segmentation violation error and it means that something is either missing or being specified inconsistently. I presume you are using the "Fuel Cell & Electrolysis" module. The first thing that catches the eye is the (CC-GC-CAT-ELE-CAT-GC-CC) sequence. I'd assume that CC stands for Current Collector, GC - Gas Channel, CAT - catalyst and ELE is the Electrolyte. Where is the porous gas diffusion layer that connects the current collector and the reaction zone (catalyst)? Can the current flow through it?
Best regards,
Aleksey.
