January 18, 2023 at 12:32 am
I use a jou script to automate the meshing process in a HPC cluster. The objects/wrap commands do not include an option to set a minimum gap between objects or an option to ignore parallel faces. I have found boundary/remesh/controls/intersect/ignore-parallel-faces, but this command requires me to remesh and restitch faces which makes the original wrapping process moot.
