I'd look carefully at the minimum cell size, given I can't even see the marker I'd question how sensible a choice it is. The courses tell you how to use the code, the size markers (usually) tell you that you're about to overcook the cell count.
New Post - Reply To: Stuck at generate the surface mesh (Watertight geometry)
