Not entirely sure why results might be trending in a direction opposite of what you expect. It might be worth mentioning that each contact pair is acting independent of the other. They will influence each other, but they do not "see" each other.
New Post - Reply To: Wear on coating and base material: Two different contacts on the same surface
