January 18, 2023 at 3:02 pm
The simple model solved to t = 0.147 s so you can see the drop.
The complex model solved to t = 0.0009 s which is such a short time that there is no visible drop. I see that you requested an end time of 0.5 s but I can also see you have set the Output Controls to have Result number of frames to be 50. I told you before to make this a larger number like 500. Why did it only solve for such a short time? Did you stop the solution or was there an error? If it was the Energy Error, you have been told how to fix that above.
- There is no issue using Part Transform to move the part closer to the floor.
- When you use Drop Height, that calculates the initial velocity at t = 0 for you. It assumes the part starts the drop with zero initial velocity. You can have Standard Earth Gravity on in all simulations.
