Thank you for posting your question. Have you changed your temperature mode in the CHARGE settings? As indicated by the error to record thermal data with the monitor, the simulation has to be set to *coupled. This setting is available in the general tab of the CHARGE solver. Alternatively, you may decide to use the HEAT solver for your analysis.
Best regards
