I unchecked "distribute solution (if possible)" in solver process settings>advanced and removed "-blas intel" and ran a simple square tube beam with a load and one end fixed and it would not solve. The "file.err" file only had 2 warnings shown below. I then checked "distribute solution (if possible)" and added back the "-blas intel" in the Additional Command Line Arguments field and re-ran model which then solved.
Entire contents of "file.err" file are below.
OM,ANSYS RELEASE 2022 R2 BUILD 22.2 UP20220516 20:38:51
*** WARNING *** CP = 1.484 TIME= 20:38:56
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING *** CP = 1.625 TIME= 20:38:56
Material number 2 (used by element 2023) should normally have at least
one MP or one TB type command associated with it. Output of energy by
material may not be available.
