January 19, 2023 at 3:25 pm
Thank you for your reply Rob. I checked the cell zone and it is water. I am using water to simulate the model. The model should be to scale and was imported using the correct units. If I understand your reply correct using the mass flow might make Fluent think the fluid is compressible when its not so it is better to use velocity inlet which might give me the higher pressure I am looking ? Thank you Rob.
