No, the solver will model using the density you define. Using a mass flow boundary just adds a couple of extra calculations into the solver: the result will be the same as using a velocity bc.
Please check the scale in Fluent. The import functions can scale things due to CAD formats and the like, hence seeing models of a 9km high water tank and 9mm high building at various times over the years.
