Hi Arvind
SEGV is a data error - could be data from memory, storage, network, etc. Which also means that nearly anything could be the cause i.e. bad input, bad hardware, program error etc. 516 GB of RAM is a lot, but still finite so there will be a limit to model size that you can solve...but I don't think that is the problem (for now). Are there any other warning or error messages in the output file you can share? If you are an Ansys customer can you please open an service request for this.
Mike
