Hello Jishnu,
I don't know the case you are working on, but polyflow does have an example you should refer to, example115 non-isothermal flow in a single screw extruder which uses the mesh superposition method in the simulation. You can get the example from ansys help site: polyflow examples
Hope this helps
Yi
