January 23, 2023 at 4:11 pm
Here it is, thanks:
As mentioned, this mismatch seems to occur only when there are 2 phases in contact with the wall. (I have 2 phases in total for the case.)
I have wall adhesion turned on for the wall and a specfied contact angle. The surface tension is modelled using CSF. I am wondering if using these models adds additional terms to the force calculation on the wall in Fluent.
Thank you very much.
